| I replaced my inner and outer tie rods to fix a vagueness in my steering, but that didn't solve the problem completely. However, when the tie rod and tension rod were disconnected, I noticed lateral play in the lower control arm. Is the best option to replace the whole control arm with a new one, or to put in a new bushing? Search says that the bushing replacement is a real PITA. Also, how frequently does the ball joint go bad on the front lower control arm? Thanks
____________________________________________________________
_____________________ Im n0t Sarcastic (Kenny): not to over do it, but you're certainly the source of high-class Z mods ZEngineer24: what do you mean by that? Im n0t Sarcastic: I just mean, your Z is one I really admire "The Z is the cause and the solution to all my problems" -- Me
"If your car was my car, I'd think it's broken" ![]() src="http://www.photodump.org/stored17/_DSC2122_originalSmall.j pg">
